Ir para o conteúdo principal
Sprinkler Head Replacement
O que você precisa
  1. Sprinkler Head Replacement, Sprinkler Head: passo 1, imagem 1 %32
    • Turn off the water supply to the sprinklers.
    • This process will vary depending on your sprinkler controller.
  2. Sprinkler Head Replacement: passo 2, imagem 1 %32
    • Find where the water supply feeds the sprinkler system and close the valve in the event of emergency or unforeseen circumstances.
  3. Sprinkler Head Replacement: passo 3, imagem 1 %32
    • Dig a hole down to the base of the sprinkler head.
    • Be careful to avoid puncturing the sprinkler line.
  4. Sprinkler Head Replacement: passo 4, imagem 1 %32
    • Using your hand or a gardening trowel, finish digging so that the sprinkler head is fully visible and is clear of dirt and debris.
  5. Sprinkler Head Replacement: passo 5, imagem 1 %32 Sprinkler Head Replacement: passo 5, imagem 2 %32
    • Unscrew the sprinkler head from the line it is attached to.
    • If is loose enough you may not need pliers.
  6. Sprinkler Head Replacement: passo 6, imagem 1 %32 Sprinkler Head Replacement: passo 6, imagem 2 %32
    • Coat the threads of the water line with teflon tape to avoid leaking.
  7. Sprinkler Head Replacement: passo 7, imagem 1 %32 Sprinkler Head Replacement: passo 7, imagem 2 %32
    • Using your hand, screw the new sprinkler head on over the teflon tape.
    • Once the sprinkler head is hand tight, use pliers to tighten it by another half turn.
  8. Sprinkler Head Replacement: passo 8, imagem 1 %32
    • Fill the hole in and pack it down to avoid unwanted movement of the new sprinkler head.
  9. Sprinkler Head Replacement: passo 9, imagem 1 %32
    • Turn the sprinkler system on.
  10. Sprinkler Head Replacement: passo 10, imagem 1 %32
    • Twist the top of the sprinkler until it is aimed where you want it.
  11. Sprinkler Head Replacement: passo 11, imagem 1 %32
    • Use a flat head screwdriver to adjust the flow of water if needed.
    • Turning right decreases the water flow. Turning left increases the water flow.
Conclusão
Enjoy your green lawn and water savings.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 68
Ao todo: 1,003
