Introdução
A damaged/ripped notebook cover leaves its important contents exposed and at risk.
With a proper cover, you can ensure the contents are safely preserved for the future.
With the help of this guide, replace the damaged cover on your spiral bound notebook.
O que você precisa
Use a binder clip on either end to hold the paper block together, excluding the damaged cover.
To reassemble your device, follow instructions 1 - 4 in reverse order.
Uma outra pessoa concluiu este guia.
