Ir para o conteúdo principal
Spin Master Hatchimal Draggle Fur Replacement
O que você precisa
  1. Spin Master Hatchimal Draggle Fur Replacement, Plastic Wing Replacement: passo 1, imagem 1 %32
    • lay the Hatchimal on its side.
  2. Spin Master Hatchimal Draggle Fur Replacement: passo 2, imagem 1 %32
    • Using the plastic opening tool, push in on the purple clip.
  3. Spin Master Hatchimal Draggle Fur Replacement: passo 3, imagem 1 %32
    • Pull the wing off of the hatchimal.
    • The wing should come off with little resistance.
  4. Spin Master Hatchimal Draggle Fur Replacement, Fur Replacement: passo 4, imagem 1 %32 Spin Master Hatchimal Draggle Fur Replacement, Fur Replacement: passo 4, imagem 2 %32
    • Cut the fur retaining zip-tie with a pair of scissors.
  5. Spin Master Hatchimal Draggle Fur Replacement: passo 5, imagem 1 %32 Spin Master Hatchimal Draggle Fur Replacement: passo 5, imagem 2 %32
    • Lift the fur up until it can't go further.
  6. Spin Master Hatchimal Draggle Fur Replacement: passo 6, imagem 1 %32 Spin Master Hatchimal Draggle Fur Replacement: passo 6, imagem 2 %32 Spin Master Hatchimal Draggle Fur Replacement: passo 6, imagem 3 %32
    • Use the spudger tool to push up on the black clip to free it.
    • Pull the clip out.
  7. Spin Master Hatchimal Draggle Fur Replacement: passo 7, imagem 1 %32 Spin Master Hatchimal Draggle Fur Replacement: passo 7, imagem 2 %32 Spin Master Hatchimal Draggle Fur Replacement: passo 7, imagem 3 %32
    • Lift fur up to reveal the next set of clips.
    • Insert a spudger to push up on the black clip to free it.
    • Pull out the clip.
  8. Spin Master Hatchimal Draggle Fur Replacement: passo 8, imagem 1 %32 Spin Master Hatchimal Draggle Fur Replacement: passo 8, imagem 2 %32
    • Lift the fur up and over the Hatchimals Head.
    • Remove the six 12mm Phillips #00 screws from then body.
  9. Spin Master Hatchimal Draggle Fur Replacement: passo 9, imagem 1 %32 Spin Master Hatchimal Draggle Fur Replacement: passo 9, imagem 2 %32
    • Pull the casing apart.
    • Remove the yellow speaker cable.
  10. Spin Master Hatchimal Draggle Fur Replacement: passo 10, imagem 1 %32 Spin Master Hatchimal Draggle Fur Replacement: passo 10, imagem 2 %32 Spin Master Hatchimal Draggle Fur Replacement: passo 10, imagem 3 %32
    • Remove the three 7mm Phillips #00 screws from the head.
    • Remove the wheel base and the circuit board carefully not to damage the spring.
  11. Spin Master Hatchimal Draggle Fur Replacement: passo 11, imagem 1 %32 Spin Master Hatchimal Draggle Fur Replacement: passo 11, imagem 2 %32
    • Push the six black fur clips out using the spudger.
    • Remove the fur completely.
Conclusão
Kimberly Searles
Membro desde: 02/14/18
340 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G5, Nance Spring 2018 Membro de USF Tampa, Team S1-G5, Nance Spring 2018
USFT-NANCE-S18S1G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 673
