Ir para o conteúdo principal
Spin Master Boxer Robot Screen Replacement
O que você precisa
  1. Spin Master Boxer Robot Screen Replacement, Robot Screen: passo 1, imagem 1 %32
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Robot Screen Replacement: passo 2, imagem 1 %32
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Robot Screen Replacement: passo 3, imagem 1 %32
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Robot Screen Replacement: passo 4, imagem 1 %32 Spin Master Boxer Robot Screen Replacement: passo 4, imagem 2 %32
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Robot Screen Replacement: passo 5, imagem 1 %32
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
Conclusão
Uma outra pessoa concluiu este guia.
Lauren Roide
Membro desde: 04/16/19
739 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G1, Maness Spring 2019 Membro de Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 678
