Ir para o conteúdo principal
Sphero Ollie Tire and Hubcap Replacement
O que você precisa
  1. Sphero Ollie Tire and Hubcap Replacement, Tires and Hubcaps: passo 1, imagem 1 %32
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie Tire and Hubcap Replacement: passo 2, imagem 1 %32 Sphero Ollie Tire and Hubcap Replacement: passo 2, imagem 2 %32
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
Conclusão
Kakkada Tho
Membro desde: 10/18/17
402 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team S1-G3, Rose Fall 2017 Membro de UW Tacoma, Team S1-G3, Rose Fall 2017
UWT-ROSE-F17S1G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 2,976
