Ir para o conteúdo principal
Sphero Ollie Battery Replacement
O que você precisa
  1. Sphero Ollie Battery Replacement, Tires and Hubcaps: passo 1, imagem 1 %32
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie Battery Replacement: passo 2, imagem 1 %32 Sphero Ollie Battery Replacement: passo 2, imagem 2 %32
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
  3. Sphero Ollie Battery Replacement, Motherboard: passo 3, imagem 1 %32
    • Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
    • Remove the plastic tire frame from the device
  4. Sphero Ollie Battery Replacement: passo 4, imagem 1 %32 Sphero Ollie Battery Replacement: passo 4, imagem 2 %32
    • Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
    • Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
  5. Sphero Ollie Battery Replacement: passo 5, imagem 1 %32 Sphero Ollie Battery Replacement: passo 5, imagem 2 %32
    • Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
    • Loosen and remove the 10mm screws holding the antenna to the case.
    • Gently remove mother board from the case with an upward motion.
  6. Sphero Ollie Battery Replacement, Battery: passo 6, imagem 1 %32 Sphero Ollie Battery Replacement, Battery: passo 6, imagem 2 %32 Sphero Ollie Battery Replacement, Battery: passo 6, imagem 3 %32
    • After you have removed the motherboard, use a JIS #1 screwdriver to remove the four 10mm Screws holding in the cog shields.
    • Next, you want to pull apart the clips (two on each side) holding the top piece of the shield to the frame.
    • Then, once you have freed the cogs, you can lift the cog and remove it from the frame.
    • To completely remove the cog shield out of the way, carefully remove the black pin connectors from the slot in the shield.
  7. Sphero Ollie Battery Replacement: passo 7, imagem 1 %32 Sphero Ollie Battery Replacement: passo 7, imagem 2 %32
    • Once you have removed the cog out of the way, you can then pinch the clip to access the battery.
    • To remove the battery, simply pull on it with slight force as it is held tight by adhesives.
Conclusão
11 outras pessoas executaram este guia.
Krystal Hedrick
Membro desde: 10/30/17
358 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S1-G3, Rose Fall 2017 Membro de UW Tacoma, Team S1-G3, Rose Fall 2017
UWT-ROSE-F17S1G3
Membros da 4
Autoria de 5 guias
7 comentários
How do you buy a new battery, where do you get them from?
Alex - Responder
Alex,
Amazon (Uxcell Power Supply DC 3.7 V 1000 MAh 803040 Li-ion rechargeable lithium Polymer Li- Po Battery
Keith Johnson -
Yes I need to find a battery as well
Keith Johnson - Responder
Need a battery email me terrys2207@yahoo.co.uk
Terry Saunders - Responder
Can I get a motherboard replaced in ollie. Please help me with reply to my email sgandham1980@icloud.com
gandham santhosh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 75
Duração total: 7,144
