Ir para o conteúdo principal
Sphero Mini Battery Replacement
O que você precisa
  1. Sphero Mini Battery Replacement, Remove the shell: passo 1, imagem 1 %32 Sphero Mini Battery Replacement, Remove the shell: passo 1, imagem 2 %32
    • Before you start, you should discharge your Sphero Mini’s battery below 25%. Usually, you can discharge the battery by playing with Sphero for around 45 mins on a full charge. Damaged batteries can start fires.
    • It’s probably a good idea to “Turn Off” your Sphero as well. You can do this from the Play or Edu app.
    • Remove the outer shell by squeezing it until it pops off.
  2. Sphero Mini Battery Replacement, Open the casing: passo 2, imagem 1 %32
    • Next, you’ll need to open the casing. Unscrew the 2 phillips screws on either side of the idler wheels.
    • Remember to keep track of your screws!
  3. Sphero Mini Battery Replacement, Remove the main board: passo 3, imagem 1 %32 Sphero Mini Battery Replacement, Remove the main board: passo 3, imagem 2 %32
    • The main board is also held in with two screws - go ahead and remove them.
    • You may need to slide the Bluetooth antenna’s sheath out of the way of one of the screws.
    • Again, keep track of your screws! These are a different length than the case screws.
    • Once the screws are out, pull the board directly up.
    • Everything is connected through some pin headers, so don’t worry about disconnecting any ribbon cables.
    • If one of the cables tries to come up with the mainboard, just pull it off and return it to its place.
  4. Sphero Mini Battery Replacement, Remove the battery: passo 4, imagem 1 %32 Sphero Mini Battery Replacement, Remove the battery: passo 4, imagem 2 %32
    • There should be a small plastic sheet adhered to the top of the battery. Gently peel it off - we’re going to use it to lift the battery.
    • This might not be the best way to do it, but it seems to be the easiest for anyone not familiar with this type of stuff.
    • Use the plastic sheet to carefully pull upwards at the edge of the yellow tape on the battery. This should help release the small amount of adhesive.
    • Once the adhesive releases, gently pull the battery out of the way.
    • Then, you’ll need to get its connector out of the way. If it’s giving you trouble, try wiggling it a little to coax it out.
  5. Sphero Mini Battery Replacement, Insert the new battery: passo 5, imagem 1 %32 Sphero Mini Battery Replacement, Insert the new battery: passo 5, imagem 2 %32
    • If your battery has adhesive, peel off the protective layer.
    • Place the new battery into the slot.
    • Push the connector into the slot where the previous one was.
    • Make sure the polarities are in the same orientation as your old battery.
    • Stick that plastic sheet on top of the new battery.
  6. Sphero Mini Battery Replacement, Reinstall the main board: passo 6, imagem 1 %32 Sphero Mini Battery Replacement, Reinstall the main board: passo 6, imagem 2 %32
    • Align the pins on the bottom of the board with the connectors below.
    • Push the board down securely.
    • Replace those 2 screws we took out earlier. (They’re the shorter pair in case you forgot).
  7. Sphero Mini Battery Replacement, Put the top case back on: passo 7, imagem 1 %32 Sphero Mini Battery Replacement, Put the top case back on: passo 7, imagem 2 %32
    • This is mostly self-explanatory - just remember to line the hole up with the Micro USB port.
  8. Sphero Mini Battery Replacement, Put the shell back on: passo 8, imagem 1 %32 Sphero Mini Battery Replacement, Put the shell back on: passo 8, imagem 2 %32
    • Again, this is self-explanatory - just pop the main thingimajig between the shell and snap it shut.
Conclusão
You did it! Hope this helps you get even more fun out of your Mini.
3 outras pessoas executaram este guia.
Carter
Membro desde: 01/09/21
256 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 30
Últimos 30 dias: 73
Duração total: 1,066
