Ir para o conteúdo principal
Speaker Assembly Replacement
O que você precisa
  1. Speaker Assembly Replacement, Speaker Assembly Replacement: passo 1, imagem 1 %32
    • Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
  2. Speaker Assembly Replacement: passo 2, imagem 1 %32
    • Remove the four T-8 screws (15 mm long) from the black speaker face.
  3. Speaker Assembly Replacement: passo 3, imagem 1 %32
    • Pry the two rubber end pieces loose enough to pry off two pieces of the long plastic casing from the speaker body using a metal spudger.
  4. Speaker Assembly Replacement: passo 4, imagem 1 %32
    • Pry the two remaining rubber pieces of the casing completely away from the body of the speaker with the same metal pry tool.
  5. Speaker Assembly Replacement: passo 5, imagem 1 %32 Speaker Assembly Replacement: passo 5, imagem 2 %32
    • Once you have removed the outer blue casing, four T-8 screws (15 mm long) will be revealed on each corner. After removing these screws, simply pull the top part of the speaker way from the body to get the the inner part of the speaker.
  6. Speaker Assembly Replacement: passo 6, imagem 1 %32
    • Once you have gotten to the internal parts of the speaker, there are seven wires connecting the speaker plate to the body of the speaker. Pinch the release tabs at the top of each of the four main wires to remove them.
  7. Speaker Assembly Replacement: passo 7, imagem 1 %32 Speaker Assembly Replacement: passo 7, imagem 2 %32 Speaker Assembly Replacement: passo 7, imagem 3 %32
    • Simply pull the thin wires on each side to remove them from their attachment points.
    • Remove the final red and black wire by gently pulling it apart.
    • This will ultimately detach the speaker plate from the base.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 1,770
