Ir para o conteúdo principal
Spark Test
O que você precisa
  1. Spark Test, Safety precautions: passo 1, imagem 1 %32 Spark Test, Safety precautions: passo 1, imagem 2 %32
    • Flip the power switch into the STOP position.
    • Make sure the engine is cool to the touch before proceeding.
  2. Spark Test, Remove the muffler cover: passo 2, imagem 1 %32 Spark Test, Remove the muffler cover: passo 2, imagem 2 %32
    • Use a T27 Torx screwdriver to remove the two screws securing the bottom of the muffler cover to the motor.
  3. Spark Test: passo 3, imagem 1 %32 Spark Test: passo 3, imagem 2 %32 Spark Test: passo 3, imagem 3 %32
    • Tilt the muffler cover up, hinging along the top edge, until it can be removed from the motor cover.
    • Remove the muffler cover.
  4. Spark Test: passo 4, imagem 1 %32 Spark Test: passo 4, imagem 2 %32
    • Pull the spark plug boot straight off of the spark plug.
  5. Spark Test, Connect the spark tester: passo 5, imagem 1 %32 Spark Test, Connect the spark tester: passo 5, imagem 2 %32
    • Connect the spark plug boot to the left terminal of the ignition checker.
  6. Spark Test: passo 6, imagem 1 %32
    • Connect the ignition checker alligator clip to a metal surface on the motor to ground the accessory cord.
  7. Spark Test: passo 7, imagem 1 %32
    • Set the spark gap to 6 mm by turning the spark gap adjustment knob counterclockwise.
    • Do not set the spark gap unnecessarily wide—a high voltage may damage the ignition coil.
  8. Spark Test: passo 8, imagem 1 %32
    • Flip the power switch into the ON position.
  9. Spark Test: passo 9, imagem 1 %32 Spark Test: passo 9, imagem 2 %32 Spark Test: passo 9, imagem 3 %32
    • Hold the spark tester by the handle on the bottom. Do not touch the terminals or spark window while the test is being conducted.
    • Watch for a spark in the spark window while a second person pulls the starter to crank the engine.
    • Consult the ignition checker instruction manual to troubleshoot the device.
Conclusão
Sam Omiotek
Membro desde: 02/25/19
68.080 Reputação
Autoria de 288 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 249
