Pular para o conteúdo principal
Introdução
If your sound card is damaged or broken or you're having trouble with the sound within your laptop, replace the sound card using this guide.
  1. Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop. Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  2. Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it. Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  3. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Use the tweezers to remove the two connecting wires.
    • Use the tweezers to remove the two connecting wires.
  5. Using the Phillips #1 screwdriver, remove the two 2.5mm screws holding down the card.
    • Using the Phillips #1 screwdriver, remove the two 2.5mm screws holding down the card.
  6. Lift and pull the sound card away from the computer.
    • Lift and pull the sound card away from the computer.
Conclusão
Armani Tayeh
Membro desde: 19-03-2018
411 reputação
4 Guias de autoria
Equipe
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Todo: 57
