Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
  1. Place the projector upside-down to access the screws on the bottom. Remove five 9mm long screws with a Phillips 1 screwdriver. Remove five 9mm long screws with a Phillips 1 screwdriver.
    • Place the projector upside-down to access the screws on the bottom.
    • Remove five 9mm long screws with a Phillips 1 screwdriver.
  2. Turn the projector on its side.
    • Turn the projector on its side.
    • Remove one 9mm Phillips 1 screw
  3. Place the projector right side up and lift the top panel up and put it to the side. Place the projector right side up and lift the top panel up and put it to the side.
    • Place the projector right side up and lift the top panel up and put it to the side.
  4. Locate the metal panel on the right hand side. Remove two 7mm screws Remove two 7mm screws
    • Locate the metal panel on the right hand side.
    • Remove two 7mm screws
  5. Lift the panel up slightly and forward to remove it completely. Lift the panel up slightly and forward to remove it completely. Lift the panel up slightly and forward to remove it completely.
    • Lift the panel up slightly and forward to remove it completely.
  6. Remove five 9mm screws with a Phillips 1 screwdriver
    • Remove five 9mm screws with a Phillips 1 screwdriver
    • Remove one 11mm screws with a Phillips one screwdriver
  7. Remove two 5mm screws with a Phillips 2 screwdriver
    • Remove two 5mm screws with a Phillips 2 screwdriver
  8. Remove all clips from mother board.
    • Remove all clips from mother board.
    • There are two additional clips underneath the mother board that need to be disconnected as well.
  9. To remove the ribbon cables, lift up on the black hinge with a fingernail or the tip of your spudger. Now, use a spudger or a barbecue skewer to lift the cable out. Now, use a spudger or a barbecue skewer to lift the cable out.
    • To remove the ribbon cables, lift up on the black hinge with a fingernail or the tip of your spudger.
    • Now, use a spudger or a barbecue skewer to lift the cable out.
  10. Lift the board up slowly, making sure there are no snagged cables. Unplug the two power cables coming into the board. Remove the mother board from the device.
    • Lift the board up slowly, making sure there are no snagged cables.
    • Unplug the two power cables coming into the board.
    • Remove the mother board from the device.
  11. Remove two clips by pinching and pulling up on the connector. Remove two clips by pinching and pulling up on the connector.
    • Remove two clips by pinching and pulling up on the connector.
  12. You can now remove the power supply. You can now remove the power supply.
    • You can now remove the power supply.
Conclusão
Matt Block
Membro desde: 30/11/2017
256 Reputação
2 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
134 Membros
14.651 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 23
