O que você precisa
Press down the release button on the bottom left corner of the face plate.
Then remove the face plate carefully.
Ferramenta utilizada nesse passo:Heavy-Duty Spudger$4.99
Insert the flat end of the Heavy-duty Spudger into the opening you created.
Slide it to the right carefully, until you feel the screen pop off.
Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
Quase terminado!
Conclusão
