O que você precisa
Press down the release button on the bottom left corner of the face plate.
Then remove the face plate carefully.
Ferramenta utilizada nesse passo:Phillips #0 Screwdriver$5.49
Using the Phillips #0 Screwdriver, unscrew the 3 screws (length - 7.5mm) on the front of the device.
Ferramenta utilizada nesse passo:Phillips #1 Screwdriver$5.49
Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
Remove side-metal plates gently.
Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
Lift off the top plate.
Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
Using the Phillips #0 Screwdriver, unscrew the 4 dark-silver screws (length - 3.71mm).
Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
The CD Drive Motherboard is located on the under-side of the CD Drive itself.
Please refer to the iFixit soldering guide to remove the CD Drive Motherboard.
Uma outra pessoa concluiu este guia.
