Ir para o conteúdo principal
Sony Xperia Z5 Charging Port Flex Replacement
O que você precisa
  1. Sony Xperia Z5 Charging Port Flex Replacement, Charging Port Flex: passo 1, imagem 1 %32 Sony Xperia Z5 Charging Port Flex Replacement, Charging Port Flex: passo 1, imagem 2 %32
    • Remove SIM card tray.
  2. Sony Xperia Z5 Charging Port Flex Replacement: passo 2, imagem 1 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 2, imagem 2 %32
    • Heat the back cover to soften the adhesive sticker.
    • Place the suction cup and inert metal opening tool to open a gap from top side.
  3. Sony Xperia Z5 Charging Port Flex Replacement: passo 3, imagem 1 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 3, imagem 2 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 3, imagem 3 %32
    • Insert the guitar pick and slide it to cut the adhesive sticker underneath.
    • Remove back cover.
  4. Sony Xperia Z5 Charging Port Flex Replacement: passo 4, imagem 1 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 4, imagem 2 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 4, imagem 3 %32
    • Release battery connector and pull off the adhesive tape underneath.
    • Pry up battery.
  5. Sony Xperia Z5 Charging Port Flex Replacement: passo 5, imagem 1 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 5, imagem 2 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 5, imagem 3 %32
    • Release rear camera connector, front camera connector, audio jack flex connector and main flex connector on the motherboard and remove the screws there.
    • Take away the plastic bracket.
  6. Sony Xperia Z5 Charging Port Flex Replacement: passo 6, imagem 1 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 6, imagem 2 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 6, imagem 3 %32
    • Remove metal cover securing loudspeaker and twist off screws.
    • Pry up and loosen the bottom side of main flex assembly.
  7. Sony Xperia Z5 Charging Port Flex Replacement: passo 7, imagem 1 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 7, imagem 2 %32
    • Remove main flex. ( Attention: the fingerprint sensor connector is here, be careful to loosen it)
  8. Sony Xperia Z5 Charging Port Flex Replacement: passo 8, imagem 1 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 8, imagem 2 %32
    • This is main flex assembly. (It comes with loudspeaker and vibration motor )
  9. Sony Xperia Z5 Charging Port Flex Replacement: passo 9, imagem 1 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 9, imagem 2 %32
    • Remove rear camera.
  10. Sony Xperia Z5 Charging Port Flex Replacement: passo 10, imagem 1 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 10, imagem 2 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 10, imagem 3 %32
    • Remove that securing bracket, then remove front camera.
  11. Sony Xperia Z5 Charging Port Flex Replacement: passo 11, imagem 1 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 11, imagem 2 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 11, imagem 3 %32
    • Release connectors on the motherboard. Remove motherboard.
  12. Sony Xperia Z5 Charging Port Flex Replacement: passo 12, imagem 1 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 12, imagem 2 %32 Sony Xperia Z5 Charging Port Flex Replacement: passo 12, imagem 3 %32
    • Remove charging port flex.
Conclusão
14 outras pessoas executaram este guia.
Lenka
Membro desde: 11/06/15
2.376 Reputação
Autoria de 6 guias
3 comentários
How about the waterproof adhesive ?
Tess - Responder
Would you have a step by step method to replace it ?
Tess - Responder
I can’t turn my phone back on. Any clues?
Bjoern Aeschlimann - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 40
Duração total: 17,528
