Ir para o conteúdo principal
Introdução
Use this guide to replace the USB cover and SD card slot cover for a Sony Xperia Z3 smartphone.
Note that although the photos in this guide feature a Z3 model with its battery and other components removed, it is not necessary to remove these components to replace the USB cover and SD card slot cover.
Vídeo de Apresentação
Sony Xperia Z3 USB Port Cover + SD/SIM Flap Replacement
  1. Use your fingers to pull firmly on the broken USB port cover until it pops out. Remove the USB port cover. Remove the USB port cover.
    • Use your fingers to pull firmly on the broken USB port cover until it pops out.
    • Remove the USB port cover.
  2. Use your fingers to firmly pull out the SD/SIM card flap. Remove the SD/SIM card flap. Remove the SD/SIM card flap.
    • Use your fingers to firmly pull out the SD/SIM card flap.
    • Remove the SD/SIM card flap.
Conclusão
13 outras pessoas concluíram este guia.
Sophia
Membro desde: 25/03/2014
43.326 Reputação
62 Guias de autoria
4 comentários
Does Z3 and Z3V have same size USB flaps?
Sudip Shrestha - Responder
i need for model D6633
Umer Farooq -
ineed both same size
Umer Farooq -
Part of the white plastic end connected to the old USB charge port cover flap on my Sony XperiaZ3v is still inside my phone. How do I get that broken piece out of the phone before installing the new USB cover in the phone?
Narda Dawidowicz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 20,553
