Ir para o conteúdo principal
Sony Xperia Z3 USB cover and SD card slot cover Replacement
Vídeo de Apresentação
Sony Xperia Z3 USB Port Cover + SD/SIM Flap Replacement
  1. Sony Xperia Z3 USB cover and SD card slot cover Replacement, USB cover and SD card slot cover: passo 1, imagem 1 %32 Sony Xperia Z3 USB cover and SD card slot cover Replacement, USB cover and SD card slot cover: passo 1, imagem 2 %32 Sony Xperia Z3 USB cover and SD card slot cover Replacement, USB cover and SD card slot cover: passo 1, imagem 3 %32
    • Use your fingers to pull firmly on the broken USB port cover until it pops out.
    • Remove the USB port cover.
  2. Sony Xperia Z3 USB cover and SD card slot cover Replacement: passo 2, imagem 1 %32 Sony Xperia Z3 USB cover and SD card slot cover Replacement: passo 2, imagem 2 %32 Sony Xperia Z3 USB cover and SD card slot cover Replacement: passo 2, imagem 3 %32
    • Use your fingers to firmly pull out the SD/SIM card flap.
    • Remove the SD/SIM card flap.
Conclusão
13 outras pessoas executaram este guia.
Sophia
Membro desde: 03/25/14
43.810 Reputação
Autoria de 62 guias
4 comentários
Does Z3 and Z3V have same size USB flaps?
Sudip Shrestha - Responder
i need for model D6633
Umer Farooq -
ineed both same size
Umer Farooq -
Part of the white plastic end connected to the old USB charge port cover flap on my Sony XperiaZ3v is still inside my phone. How do I get that broken piece out of the phone before installing the new USB cover in the phone?
Narda Dawidowicz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 36
Duração total: 21,072
