Ir para o conteúdo principal
Sony Xperia Z3 Dual Loudspeaker Assembly Replacement
O que você precisa
Vídeo de Apresentação
  1. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: passo 1, imagem 1 %32 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: passo 1, imagem 2 %32 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: passo 1, imagem 3 %32
    • Heat to soften back cover sticker.
    • Place the suction cup and try to open a gap.
    • Insert the guitar pick into the gap.
  2. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 2, imagem 1 %32 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 2, imagem 2 %32
    • Slide the guitar pick to cut the sticker and remove the back cover.
  3. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 3, imagem 1 %32 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 3, imagem 2 %32 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 3, imagem 3 %32
    • Remove two screws by Philips screwdriver.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove the small vibrator securing bracket.
  4. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 4, imagem 1 %32 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 4, imagem 2 %32 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 4, imagem 3 %32
    • Remove the securing cover. It's thin and weak, please be careful when remove it.
  5. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 5, imagem 1 %32 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 5, imagem 2 %32 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 5, imagem 3 %32
    • Pry up the assembly and carry it out.
  6. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 6, imagem 1 %32 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 6, imagem 2 %32
    • Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
Conclusão
4 outras pessoas executaram este guia.
Sophia
Membro desde: 03/25/14
43.810 Reputação
Autoria de 62 guias
2 comentários
this is all good but is there a link to the part ?
morten hundevad - Responder
EBay search Sony z3 replacement loud speaker cost's around £3-£5
Martin Lb -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 4,405
