Ir para o conteúdo principal
Sony Xperia Z3 Dual Earpiece Speaker Replacement
O que você precisa
  1. Sony Xperia Z3 Dual Earpiece Speaker Replacement, Earpiece Speaker: passo 1, imagem 1 %32
    • Power off and remove two SIM card trays at first before earpiece speaker replacement.
  2. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 2, imagem 1 %32 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 2, imagem 2 %32 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 2, imagem 3 %32
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick.
    • Slide guitar pick to cut the sticker.
  3. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 3, imagem 1 %32
    • Remove back cover.
  4. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 4, imagem 1 %32 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 4, imagem 2 %32 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 4, imagem 3 %32
    • It's easy to remove the battery.
  5. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 5, imagem 1 %32
    • Twist off two screws at first.
  6. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 6, imagem 1 %32 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 6, imagem 2 %32 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 6, imagem 3 %32
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 7, imagem 1 %32 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 7, imagem 2 %32 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 7, imagem 3 %32
    • Release all the connectors connecting with motherboard.
    • Pry motherboard up from left side. It's really hold tightly by some hidden keys, so be careful.
    • Remove motherboard.
  8. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 8, imagem 1 %32 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 8, imagem 2 %32 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 8, imagem 3 %32
    • Remove the blocker beside earpiece speaker and you can see the breakout to pry up the speaker.
    • Remove earpiece speaker finally.
Conclusão
13 outras pessoas executaram este guia.
Sophia
Membro desde: 03/25/14
43.810 Reputação
Autoria de 62 guias
3 comentários
Thanks for the guide, it worked very well.
Maybe it's worth mentioning that there's a sticker at the back of the battery and you shouldn't be afraid to just pull the battery out.
Steven Kolenberg - Responder
Hai. Can you give me the link to buy the earpiece? Tq
Wafi Sams - Responder
Thanks for the guide, however my ear piece speaker now rattles when i play music at medium levels. I have tried installing additional adhesive to it, but still cracks.
Tony Ho - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 16,183
