Introdução
Sony Xperia Z3 battery is non-removable. When you encountered the problem with battery, it's a little complex to replace.
O que você precisa
Vídeo de Apresentação
Heat the back cover to soften the adhesive sticker.
Use the suction cup to open a gap from top side or bottom side.
12 outras pessoas executaram este guia.
2 comentários
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Just finished this guide thank you!
