Ir para o conteúdo principal
Sony Xperia Z3 Dual Back Cover Replacement
O que você precisa
Vídeo de Apresentação
  1. Sony Xperia Z3 Dual Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
  2. Sony Xperia Z3 Dual Back Cover Replacement: passo 2, imagem 1 %32
    • Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
  3. Sony Xperia Z3 Dual Back Cover Replacement: passo 3, imagem 1 %32
    • Insert guitar pick into the gap and slide to cut the sticker around the back cover.
  4. Sony Xperia Z3 Dual Back Cover Replacement: passo 4, imagem 1 %32
    • Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
  5. Sony Xperia Z3 Dual Back Cover Replacement: passo 5, imagem 1 %32
    • Remove the back cover easily. It comes with camera lens and NFC.
    • And you can place your new back cover, press the adhesive sticker and done the replacement.
Conclusão
12 outras pessoas executaram este guia.
Sophia
Membro desde: 03/25/14
43.810 Reputação
Autoria de 62 guias
2 comentários
My Xperia z3 was broken back cover if I replace this cover, this waterproof features are still working or not? guys I need your suggestions
Winstonmary Dimagnaong - Responder
Are you sure that the replacement parts mentioned above would work for the Z3 DUAL as well? I believe it has a slightly different size or shape compared to the regular Z3
Shevek - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 21,136
