Ir para o conteúdo principal
Sony Xperia Z3 Compact Main Flex Replacement
O que você precisa
  1. Sony Xperia Z3 Compact Main Flex Replacement, Main Flex: passo 1, imagem 1 %32 Sony Xperia Z3 Compact Main Flex Replacement, Main Flex: passo 1, imagem 2 %32 Sony Xperia Z3 Compact Main Flex Replacement, Main Flex: passo 1, imagem 3 %32
    • First, heat up.
    • And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover.
    • Finally, remove the back cover.
  2. Sony Xperia Z3 Compact Main Flex Replacement: passo 2, imagem 1 %32 Sony Xperia Z3 Compact Main Flex Replacement: passo 2, imagem 2 %32 Sony Xperia Z3 Compact Main Flex Replacement: passo 2, imagem 3 %32
    • Disconnect the NFC antenna.
    • Unscrew the screws holding the black midframe in place.
    • Remove back frame.
  3. Sony Xperia Z3 Compact Main Flex Replacement: passo 3, imagem 1 %32
    • Disconnect the battery flex cable.
  4. Sony Xperia Z3 Compact Main Flex Replacement: passo 4, imagem 1 %32 Sony Xperia Z3 Compact Main Flex Replacement: passo 4, imagem 2 %32 Sony Xperia Z3 Compact Main Flex Replacement: passo 4, imagem 3 %32
    • Remove rear camera bracket.
    • Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
    • Remove rear camera.
  5. Sony Xperia Z3 Compact Main Flex Replacement: passo 5, imagem 1 %32 Sony Xperia Z3 Compact Main Flex Replacement: passo 5, imagem 2 %32 Sony Xperia Z3 Compact Main Flex Replacement: passo 5, imagem 3 %32
    • Release connectors and screw.
  6. Sony Xperia Z3 Compact Main Flex Replacement: passo 6, imagem 1 %32 Sony Xperia Z3 Compact Main Flex Replacement: passo 6, imagem 2 %32 Sony Xperia Z3 Compact Main Flex Replacement: passo 6, imagem 3 %32
    • Remove motherboard.
  7. Sony Xperia Z3 Compact Main Flex Replacement: passo 7, imagem 1 %32 Sony Xperia Z3 Compact Main Flex Replacement: passo 7, imagem 2 %32 Sony Xperia Z3 Compact Main Flex Replacement: passo 7, imagem 3 %32
    • Remove main flex.
Conclusão
5 outras pessoas executaram este guia.
Sophia
Membro desde: 03/25/14
43.810 Reputação
Autoria de 62 guias
6 comentários
hi dear
my mobile (sony xperia z3 mini ) it problem in screen, i changed screen but still not work always black how can i do to fixed my mobile ???? plz help me
BR
Swren
swren1987 - Responder
Sony's TFT LCD IPS Fuse exploded on Logic Board. Just solder it out. Use a Good Solder + Microscope.
Compact Z3: https://youtu.be/B3GHVfFs2hU?t=263
Logic BoardCHF 23.04 | 32GB Original Motherboard Für Sony Xperia Z3 MINI D5803 D5833 100% Entsperrt Mainboard Android OS Logic board Mit Chips ersetzen++https://a.aliexpress.com/_BUGwJ5++
TFT LCD IPSCHF 17.92 | Original 4.6 ''Für Sony Xperia Z3 compact z3 mini D5803 D5833 LCD Display Touchscreen Digitizer Montage mit rahmen ohne F++https://a.aliexpress.com/_B0hkDt++
Normal Big Z3: ++https://youtu.be/ZUm7n0tCZVM?t=45++
5803 = EU + USA
5833 = Australia + Asia
++https://www.quora.com/What-is-the-differ...
Buddha Buddha -
I can not loosen a screw, what can I do?
Piero Sabino - Responder
Hey Fixit, I will repair my Wifi, but I can not find the component parts on the mainboard on the Z3c
Have a description where is the wifi component similar to these video because on the Z3Compact?
http://www.youtube.com/watch?v=dvq1zkiu4...
Sofie - Responder
is there label imei or meid in it ???
Ardians Faqih - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 23
Duração total: 17,129
