Ir para o conteúdo principal
Sony Xperia Z2 Main Camera Replacement
O que você precisa
Vídeo de Apresentação
  1. Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: passo 1, imagem 1 %32 Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: passo 1, imagem 2 %32 Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: passo 1, imagem 3 %32
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Main Camera Replacement: passo 2, imagem 1 %32 Sony Xperia Z2 Main Camera Replacement: passo 2, imagem 2 %32 Sony Xperia Z2 Main Camera Replacement: passo 2, imagem 3 %32
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Main Camera Replacement: passo 3, imagem 1 %32 Sony Xperia Z2 Main Camera Replacement: passo 3, imagem 2 %32
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Main Camera Replacement, Main Camera: passo 4, imagem 1 %32 Sony Xperia Z2 Main Camera Replacement, Main Camera: passo 4, imagem 2 %32
Conclusão
9 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
196.103 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
331 Membros
Autoria de 1.458 guias
7Comentários do guia
Where can I buy Spear main camera bucz my main camera is not functioning. Please help please... Please link me a website where I can buy it online.
Kushal maharjan - Responder
search ebay for "sony xperia z2 camera", unbelievable right?
deftoner -
I crashed my sony z2 and after i fix the screen i but the camera and it's overheated and doesn't work.what i must do and change
chris kat - Responder
I replied the comment to the other guy
deftoner -
My Camara get overheated too, and does not work, trying to replace it, where can I get it replace and how much does it go for thanks
Tripleboss - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 9,304
