Introdução
You can reset your device to its original factory settings, with or without deleting all of your personal data. This action is sometimes necessary if your device stops functioning properly.
O que você precisa
Vídeo de Apresentação
SOFT RESET
You can force your device to shut down in situations where it stops responding or won't restart normally. No settings or personal data get deleted.
Micro SD card cover
Micro USB connector cover
Micro SIM card cover
Open the micro SIM card cover and you will see a small red button. Press it and you will feel three vibrations and device will shuts down.
FACTORY DATA / HARD RESET
Go to Settings > Backup & Reset
You have option to backup your data (you must have Google account).
After Factory data reset the smartphone will restart.
Did you do it successfully?
I'm dumb and put my phone in water help
I am so stupid
I am dumb and put my phone in water help
I am so. Dumb
69 outras pessoas executaram este guia.
29 comentários
I will alrrady presss red bottan then he 3time vibration after no responses. Why I want to broken my pattern lock ...pls help
the same as yours
forget my paaword
i cant get into my menu
اصول صحیح مطالعه
Normally if you press for 5 sec the ON/OFF button and Volume + button , It will Soft reset
it worked :) thaks!
heraa -
It worked for Z1 Compact, thanks
Hi, I did as per your quote. My mobile screen got froze and did the ON/OFF button and Volume + . And when I switch it ON normally, it doesn’t turn ON. It just flashes Red LED light 3times. I have changed and inserted with NEW battery, but still it doesn’t turn ON.
Also I won’t loose any of my data, when I did the SOFT RESET.
ram -
Hey I have z1 when I touch settings operate speaking also how can I fix it ?
I've done all this several times but still no luck my son's phone has a number pin and we have no code for it and it's not doing a factory reset how can I fix it
Try what i suggested below :) Hope that helps
If you have signed into your google account on your phone, you should be able to sign into Android Device Manager: https://www.google.com/android/deviceman..., here you will be able to do a password removal and/or a factory reset in which everything on the phone is deleted.
Hope everything works now :)
Why is that, everytime i press ' erase everything' the 'Confirmation of PIN' will pop-up, but i dont have pin that register. Help! What to do?!
Also, the problem of my xperia z1 is that, when i open it it just stay good for 15secs. Then it says ' (etc. Not responding) then it gives 2 options, one is WAIT and the other is OK, then if i press ok and wait. The screen will turn black. Then it will restart automatically again and again.
refulgentel: I got exactly the same problem since yesterday, I tried to do the hard reset( with 3 different methods) but that's didnt worked
Fouond any solution ? Same here
kacmar -
Hi, I want to do the factory data reset my phone sony experia z1.
After click erase everything button, it request to confirm password?
but it pop up try again.
which password should i use?
the above procedures doesnt work at all. had to use Sony PC Companion software and select Repair Device to reset/erase the phone.
Not it will not work, because it will appear type pascode.
my sony z1 automatic shut down,software change,battery change,other than the board the whole changed same problem.
but main camera removing mobile ready
camera fixing,or camera changing same problm
eany solution?
When i put my card sim in he begin dowing stufs . Can i fix it pls help me.
i cant on my phone. Its keep on and off.. How to do hard reset
Try already but the red small button is not functioning..and totally not open..but if I charge is OK..
Roda Ledesma Dumayag - Responder
I try already to preS's that red small button but no responce..totally shutdown if I charge mobile is OK..but not open..tnx
