Introdução
Does your phone run out of juice faster? Does your phone require you to charge it more often? Replacing the battery may solve these problems.
O que você precisa
Use the small suction cup to lift the back panel:
Press the small suction cup on to the middle of the back panel.
While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
16 outras pessoas executaram este guia.
5 comentários
Does this fix change the waterproof efficiency?
Hello atilasilva,
I guess so. Since you have to either replace the complete back cover or at least the glue line around the back cover I think the phone will not be completely waterproof again. It still may be solid splash proof.
Battery available for $14.99 on eBay http://www.ebay.com/itm/112267192605
I am about to follow your procedures to do a battery replacement. I have read your instructions, one question is if any need to use some glues to fix the back panel of the Sony Phone? From your instruction you did not mention the use of any glue at all, I am a bit concerned because at the moment my Sony phone both front and back panes are already loosen. I was told this is due to the old battery expanding.
Thanks for your help
