Introdução
This guide will lead you through the steps necessary to replace your rear-facing camera if it if not functioning properly. It has two pre-requisite guides.
O que você precisa
Turn hair dryer to medium heat.
Slowly move the hair dryer along the seams on the back of the phone. Keep the dryer a few inches away from the case.
Circulate the dryer for a full minute to soften the adhesive binding the phone together.
Slide the spudger firmly along the right side of the battery, loosening the adhesive between the casing and battery.
Insert the spudger in the bottom-center to further loosen the adhesive. Carefully separate the battery from the phone by sliding the spudger vertically underneath the battery and prying up. This may take some time and work as the adhesive is very strong.
Remove the one 3 mm screw with the Phillips #000 screwdriver. The screw is located at the top right corner of the motherboard. The motherboard is the green/silver circuit board at the top of the phone.
Using with the plastic opening tool, pry up firmly from the bottom and top of the plastic housing. The housing is black and located at the top right corner of the phone.
Release the charging cover, located on the right side of the phone at the top. This should cause the housing piece to pop out effortlessly.
Release the copper tape located at the top middle of the phone with a plastic opening tool. This will take some force since the adhesive is rather strong.
With the plastic opening tool, release the pop connector, by lifting up to release it. The pop connector should still be attached to the copper tape.
Pull up gently on the copper tape and pop connector to remove the back camera. It should pop out easily.
12 outras pessoas executaram este guia.
3 comentários
where can i repair my sony xperia aqua camera because both rear and back camera are not working at all.
با سلام ...من به یه ایراد خوردم ...سونی زد داخل دوربین نمیره میخواستم ببینم ای سی دوربین کدومه ....ویک برده دیگه شارژ نمیکنه ....دشارژ میکنه ....سپاس
