Ir para o conteúdo principal
Sony Xperia Z Ear Speaker Replacement
O que você precisa
  1. Sony Xperia Z Ear Speaker Replacement, Battery: passo 1, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement, Battery: passo 1, imagem 2 %32 Sony Xperia Z Ear Speaker Replacement, Battery: passo 1, imagem 3 %32
    • Turn hair dryer to medium heat.
    • Slowly move the hair dryer along the seams on the back of the phone. Keep the dryer a few inches away from the case.
    • Circulate the dryer for a full minute to soften the adhesive binding the phone together.
  2. Sony Xperia Z Ear Speaker Replacement: passo 2, imagem 1 %32
    • Once the adhesive is loosened, stick the suction cup to the top-center of the back of your phone and gently pull back.
    • Gently pull back just enough to create a small gap.
  3. Sony Xperia Z Ear Speaker Replacement: passo 3, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement: passo 3, imagem 2 %32
    • Once you've opened a small space with the back cover, stick the plastic opening tool into the seam of the phone.
    • Move the tool along the seam to loosen the adhesive.
  4. Sony Xperia Z Ear Speaker Replacement: passo 4, imagem 1 %32
    • Caution: Pulling too vigorously or quickly on the suction cup could snap the back of the phone.
    • Once the adhesive has been adequately loosened, pull back slowly on the suction cup to remove the back panel of the phone.
    • The remaining adhesive should be strong enough to hold the phone together tightly upon reassembly. However, once opened the water resistance of your phone has been compromised.
  5. Sony Xperia Z Ear Speaker Replacement: passo 5, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement: passo 5, imagem 2 %32 Sony Xperia Z Ear Speaker Replacement: passo 5, imagem 3 %32
    • Now that the back is removed, the battery is visible. You now have access to the battery and its connecting components.
    • With the plastic opening tool, gently remove the connector from the motherboard.
    • Use your fingers to peel the rest of the adhesive away from the phone.
  6. Sony Xperia Z Ear Speaker Replacement: passo 6, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement: passo 6, imagem 2 %32 Sony Xperia Z Ear Speaker Replacement: passo 6, imagem 3 %32
    • With the plastic opening tool, carefully peel the white adhesive tape up from the bottom of the battery.
    • Use your fingers to peel back the rest of the adhesive tape away from the battery.
    I found this white adhesive tape just wrapped around the battery, so didn’t need to be removed
    sarah - Responder
  7. Sony Xperia Z Ear Speaker Replacement: passo 7, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement: passo 7, imagem 2 %32 Sony Xperia Z Ear Speaker Replacement: passo 7, imagem 3 %32
    • Slide the spudger firmly along the right side of the battery, loosening the adhesive between the casing and battery.
    • Flex cables run vertically down the phone underneath the battery and can be damaged easily. Make sure to only place the spudger in the indicated area.
    • Insert the spudger in the bottom-center to further loosen the adhesive. Carefully separate the battery from the phone by sliding the spudger vertically underneath the battery and prying up. This may take some time and work as the adhesive is very strong.
    it would be better to show in overlay red the two vertical cables that should not be touched; i damaged by 1 mm at the bottom one of the cable and the display is no longer working, even if can hear touch feedbacks and sound and now if if it charges well :o((
    cagnes06 - Responder
    if you do what is shown on the picture at step 7 (i did) you can still damage the cable right, because it deviates at the bottom towards the left !
    Why not start the instructions by saying "This battery replacement operation is too difficult unless you are highly experienced. You are very likely to damage the phone beyond repair. Sony prefer you to buy a new phone every 2 years when the battery fails"
    Roy Banks - Responder
    I agree that it would be better to overlay red the two vertical cables. Other than that, this step is rather time consuming, than complicated. Obviously you should be attentive to not damage the cables, but if you put moderate force during 3-4 minutes, the battery will finally separate from the case.
    Wondering if it’s safe to use hair dryer at this step.
    strixaluco - Responder
  8. Sony Xperia Z Ear Speaker Replacement, Camera: passo 8, imagem 1 %32
    • Remove the one 3 mm screw with the Phillips #000 screwdriver. The screw is located at the top right corner of the motherboard. The motherboard is the green/silver circuit board at the top of the phone.
  9. Sony Xperia Z Ear Speaker Replacement: passo 9, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement: passo 9, imagem 2 %32 Sony Xperia Z Ear Speaker Replacement: passo 9, imagem 3 %32
    • Using with the plastic opening tool, pry up firmly from the bottom and top of the plastic housing. The housing is black and located at the top right corner of the phone.
    • Release the charging cover, located on the right side of the phone at the top. This should cause the housing piece to pop out effortlessly.
    • Getting the black housing off of the phone can be tricky. Just keep prying and pulling up on the housing to get it out.
  10. Sony Xperia Z Ear Speaker Replacement, Rear Facing Camera: passo 10, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement, Rear Facing Camera: passo 10, imagem 2 %32 Sony Xperia Z Ear Speaker Replacement, Rear Facing Camera: passo 10, imagem 3 %32
    • Do not remove all the copper tape. Only remove the copper tape attached to the silver part of the motherboard.
    • Release the copper tape located at the top middle of the phone with a plastic opening tool. This will take some force since the adhesive is rather strong.
    • With the plastic opening tool, release the pop connector, by lifting up to release it. The pop connector should still be attached to the copper tape.
    • Pull up gently on the copper tape and pop connector to remove the back camera. It should pop out easily.
  11. Sony Xperia Z Ear Speaker Replacement, Front Facing Camera: passo 11, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement, Front Facing Camera: passo 11, imagem 2 %32
    • With the plastic opening tool, gently pry the red tape away from motherboard. This pop connector is located at the top right corner of the phone.
    • Using your fingers, gently pull up on the pop connector to remove the front camera. The front camera piece should lift out effortlessly.
  12. Sony Xperia Z Ear Speaker Replacement, SIM Card: passo 12, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement, SIM Card: passo 12, imagem 2 %32
    • The SIM card of the Xperia Z is located in the unlabeled slot above the power button.
    • Gently open the cover by pushing it to the left.
    • Some photos in this guide show the back cover of the phone removed. If you are only removing the SIM card, removing the case is not necessary.
  13. Sony Xperia Z Ear Speaker Replacement: passo 13, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement: passo 13, imagem 2 %32 Sony Xperia Z Ear Speaker Replacement: passo 13, imagem 3 %32
    • To avoid damage to the SIM card, be careful when removing and handling it.
    • Carefully pull the SIM card and SIM card tray out of the phone
  14. Sony Xperia Z Ear Speaker Replacement, Motherboard: passo 14, imagem 1 %32
    • Remove the two 3mm Phillips #000 screws located at the middle left and lower right of motherboard.
  15. Sony Xperia Z Ear Speaker Replacement: passo 15, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement: passo 15, imagem 2 %32 Sony Xperia Z Ear Speaker Replacement: passo 15, imagem 3 %32
    • Gently pry the three flex cables away from the motherboard. They are located on the bottom right, bottom left, and top left corners of the motherboard.
    • Leave the three flex cable flaps up and away from the motherboard. Be careful not to tear the flex cables.
  16. Sony Xperia Z Ear Speaker Replacement: passo 16, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement: passo 16, imagem 2 %32
    • With the plastic opening tool pry up the antenna located at the bottom right of the motherboard.
    • Leave the antenna up and away from the motherboard.
  17. Sony Xperia Z Ear Speaker Replacement: passo 17, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement: passo 17, imagem 2 %32 Sony Xperia Z Ear Speaker Replacement: passo 17, imagem 3 %32
    • With the plastic opening tool, firmly pry the motherboard up out of the phone case. Pry from the right side of the motherboard where the back camera was previously located.
    • Firmly lift the section up where the silver part of the motherboard comes to the edge of the green base board.
    • The motherboard has a lot of adhesive connecting it to the phone, so it will require some force to remove it.
  18. Sony Xperia Z Ear Speaker Replacement, Ear Speaker: passo 18, imagem 1 %32 Sony Xperia Z Ear Speaker Replacement, Ear Speaker: passo 18, imagem 2 %32 Sony Xperia Z Ear Speaker Replacement, Ear Speaker: passo 18, imagem 3 %32
    • Gently pry the ear speaker out of its position, making sure to keep the tool beneath the adhesive attached to the ear speaker.
Conclusão
12 outras pessoas executaram este guia.
Mollie
Membro desde: 01/29/14
1.864 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 2-7, Amido Winter 2014 Membro de Cal Poly, Team 2-7, Amido Winter 2014
CPSU-AMIDO-W14S2G7
Membros da 4
Autoria de 25 guias
6 comentários
No need to remove battery for this only unplug !!!
Because the side button flex clable is easy damage
cars1dA - Responder
@cagnes06, when you say "the display is no longer working" do you mean the screen stopped working completely? Or do you mean that while you are making calls the display no longer works? Thank you for taking the time to read and reply.
Ethan Deffenbaugh - Responder
Hi, I fixed the hear speaker without removing the battery or the rear facing camera (to retain the integrity of the copper strip) The camera just slides out of its housing when you lift out the motherboard. The other connectors just need folding back out of the way. Doing it minus all the other steps reduced the time significantly. I had everything pulled apart as necessary in about 5 minutes.
I fixed the speaker by pulling up the prongs that connect to the motherboard. My guess is that one of them was a little low, which affected the connection. Putting back together again was another 4 minutes or so, for a total of about 10 minutes. Hope that helps others avoid damaging the rear facing camera and bits under the battery.
andrew degozaru - Responder
Would it be possible to list steps that you performed (or alternatively - steps you skipped) ?
mushkevych -
thanks for the comment. as you mentioned folding the ribbons was sufficient. no need of removing the battery and copper ribbon for camera. thanks!
Mubeen Asim -
I can fully confirm that you don’t need to remove the battery in order to get to the ear speaker. I wouldn’t say that it’s a difficult task to do provided that you have proper tools. It took me around 15 minutes to disassemble my phone. My problem were interruptions when making calls and I solved it by pulling up the prongs that connect the ear speaker to the motherboard, as Andrew wrote.
Best,
Michael
Michal - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 32,875
