Ir para o conteúdo principal
Sony Xperia XZ2 Front Camera Replacement
O que você precisa
  1. Sony Xperia XZ2 Front Camera Replacement, LCD Screen: passo 1, imagem 1 %32 Sony Xperia XZ2 Front Camera Replacement, LCD Screen: passo 1, imagem 2 %32 Sony Xperia XZ2 Front Camera Replacement, LCD Screen: passo 1, imagem 3 %32
    • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
    • The phone gets very hot and can hurt the user handling it.
  2. Sony Xperia XZ2 Front Camera Replacement: passo 2, imagem 1 %32 Sony Xperia XZ2 Front Camera Replacement: passo 2, imagem 2 %32 Sony Xperia XZ2 Front Camera Replacement: passo 2, imagem 3 %32
    • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
    • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
  3. Sony Xperia XZ2 Front Camera Replacement: passo 3, imagem 1 %32 Sony Xperia XZ2 Front Camera Replacement: passo 3, imagem 2 %32
    • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
    • The screen is still attached by a connector, so do not pull the pieces apart.
  4. Sony Xperia XZ2 Front Camera Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    $3.99
    Comprar
    • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
  5. Sony Xperia XZ2 Front Camera Replacement: passo 5, imagem 1 %32
    • Gently remove the connector by using a spudger to pop it off.
  6. Sony Xperia XZ2 Front Camera Replacement, Front Camera: passo 6, imagem 1 %32
    • Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
    • Remove the one 3 mm Phillips #00 screws.
    • Remove the two 1mm Phillips #00 screws.
    • Fifteen screws should be removed in total in this step. (Not all the screws are visible in the picture.)
  7. Sony Xperia XZ2 Front Camera Replacement: passo 7, imagem 1 %32
    • Lift the metal screen shield out of the phone.
  8. Sony Xperia XZ2 Front Camera Replacement: passo 8, imagem 1 %32 Sony Xperia XZ2 Front Camera Replacement: passo 8, imagem 2 %32 Sony Xperia XZ2 Front Camera Replacement: passo 8, imagem 3 %32
    • Use the spudger to pop off the plastic protector.
  9. Sony Xperia XZ2 Front Camera Replacement: passo 9, imagem 1 %32
    • Gently pry up the battery flex connector using the spudger.
Conclusão
Chloe
Membro desde: 01/24/19
214 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S19-G5, White Winter 2019 Membro de Cal Poly, Team S19-G5, White Winter 2019
CPSU-WHITE-W19S19G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 1,012
