Introdução
In this video, i will show you how to replacement lcd screen for Sony xperia xz1 compact.
O que você precisa
Instruções em vídeo
Conclusão
5 outras pessoas executaram este guia.
3Comentários do guia
Absolutamente Perfecto. Gracias
Gabriel Torres - Responder
Hi, where can you buy that screen sticker template? Exactly that ...
My contact: gabrieltg@protonmail.com
Thanks
Hi, I have a screen that has a failed backlight, I replaced it with the replacement screen and the backlight is still broken: After some googling I found out that probably the backlight fuse is broken, Is there a possibility to change it? But I have no idea where to find a replacement fuse and it seems quite tricky to make it work on the motherboard.
Tobias - Responder
