Ir para o conteúdo principal
Sony Xperia XZ Premium Motherboard Replacement
O que você precisa
  1. Sony Xperia XZ Premium Motherboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
    • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
    • Follow this guide for directions on using the iOpener.
    Is it okay to use a hair dryer instead of iOpener?
    091 03718 - Responder
  2. Sony Xperia XZ Premium Motherboard Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
  3. Sony Xperia XZ Premium Motherboard Replacement: passo 3, imagem 1 %32
    • Take hold of the back panel with your fingers and remove.
  4. Sony Xperia XZ Premium Motherboard Replacement, Frame: passo 4, imagem 1 %32
    • Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
  5. Sony Xperia XZ Premium Motherboard Replacement: passo 5, imagem 1 %32 Sony Xperia XZ Premium Motherboard Replacement: passo 5, imagem 2 %32
    • Remove nine 3.9mm Phillips #000 screws.
    • Make sure to turn carefully in the counter-clockwise direction or you may wear out the thread and shape of the screws. You will not be able to remove the screws once they are damaged!
    • When unscrewing, remember "Left Loosey, Righty Tighty!"
  6. Sony Xperia XZ Premium Motherboard Replacement: passo 6, imagem 1 %32
    • Place the spudger under the top left corner frame piece and lift to loosen.
  7. Sony Xperia XZ Premium Motherboard Replacement: passo 7, imagem 1 %32
    • Grab hold of the top left frame piece with your fingers and gently wiggle and lift to remove.
  8. Sony Xperia XZ Premium Motherboard Replacement: passo 8, imagem 1 %32
    • Place the spudger under the bottom left frame piece and lift to loosen it.
  9. Sony Xperia XZ Premium Motherboard Replacement: passo 9, imagem 1 %32
    • Grab hold of bottom left frame piece with your fingers and lift gently.
    • When dislodging the left frame piece, carefully wiggle the piece while lifting it vertically to prevent any damage to the wedges on the frame. This applies for all of the other frame pieces you will remove after this step!
  10. Sony Xperia XZ Premium Motherboard Replacement: passo 10, imagem 1 %32
    • Place the spudger under the top right frame piece and lift to loosen it.
    このとき、バイブレーターのカバーと、バイブレーターのコネクタに注意します。無理矢理引きちぎらないようにしてください。
    satore - Responder
    上部右側フレームの下には、バイブレータがあります。バイブレータとマザーボードをつなぐコネクタはなぜか上部右上フレームに接着されています(接着されていなくてもよい気がします)。
    上部右側フレームを持ち上げる際には、そっとコネクタを外した方が安全です。
    https://youtu.be/JmN7pZdgJDU?t=133
    バイブレーターのカバーは、シリコン製です。外れやすいので見失わないようにしてください。
    satore - Responder
  11. Sony Xperia XZ Premium Motherboard Replacement: passo 11, imagem 1 %32
    • Grab hold of the top right frame piece with your fingers and lift.
  12. Sony Xperia XZ Premium Motherboard Replacement, Motherboard: passo 12, imagem 1 %32
    • Insert your nail under the top left connector and push to disconnect it.
  13. Sony Xperia XZ Premium Motherboard Replacement: passo 13, imagem 1 %32
    • Grab hold of the metal part of the connector with your fingers and lift.
  14. Sony Xperia XZ Premium Motherboard Replacement: passo 14, imagem 1 %32
    • Insert your nail under the metal part of the bottom left connector.
  15. Sony Xperia XZ Premium Motherboard Replacement: passo 15, imagem 1 %32
    • Push the bottom left connector with your finger to disconnect it.
  16. Sony Xperia XZ Premium Motherboard Replacement: passo 16, imagem 1 %32
    • Insert your nail under the center topmost connector and push to loosen it.
  17. Sony Xperia XZ Premium Motherboard Replacement: passo 17, imagem 1 %32
    • Grab hold of the top connector with your fingers and lift to disconnect it.
  18. Sony Xperia XZ Premium Motherboard Replacement: passo 18, imagem 1 %32
    • Insert your nail under the metal tab of the connector above the battery and push to loosen it.
  19. Sony Xperia XZ Premium Motherboard Replacement: passo 19, imagem 1 %32
    • Pull the metal tab of the connector towards you with your fingers to disconnect the pins.
  20. Sony Xperia XZ Premium Motherboard Replacement: passo 20, imagem 1 %32
    • Insert spudger in the gap above the battery and lift to loosen the motherboard.
    • Use the spudger to slide under the edges of the motherboard if the motherboard does not seem to loosen after the above step.
    フロントカメラの取り外し手順が省かれており、最低限カメラのシールドを止めているネジを取り外す必要があります。
    また、SIMカード、SDカードも前もって外しておかないと、マザーボードが浮いてきません。
    Takahiro Yoshinaga - Responder
  21. Sony Xperia XZ Premium Motherboard Replacement: passo 21, imagem 1 %32
    • Insert the spudger in the gap between the motherboard and the left side of the battery to further lift out the motherboard.
    この段階で既に見えていますが、バッテリと本体を固定する両面テープの耳を引っ張れば、バッテリはすぐに外れます。
    satore - Responder
  22. Sony Xperia XZ Premium Motherboard Replacement: passo 22, imagem 1 %32
    • Grab hold of the motherboard with your fingers and lift it out of the phone gently.
Conclusão
5 outras pessoas executaram este guia.
Gelene Amog
Membro desde: 04/18/18
1.165 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S18-G2, Livingston Spring 2018 Membro de Cal Poly, Team S18-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G2
Membros da 5
Autoria de 16 guias
4 comentários
Where do you buy a motherboard for the xz premium? thank you
Jonathan Storm - Responder
where can you buy a motherboard for the xz premium G8142?
dukeduane - Responder
If you know the name of the motherboard you can check on:
newegg.com
aliexpress.com
https://www.sony.com/electronics/support...
amazon.com
alibaba.com
Kristoffer Grundström -
Anyone know if you can replace the microphone on the XZ premium? I think it is attatched to the motherboard. Is it soldered on?
Tom M - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 34
Duração total: 6,438
