Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will show you how to remove the headphone jack from your Sony Xperia XA1 Ultra. The headphone jack should be repleaced if it damaged or blocked by a foreign object. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. In addition, a T5 screwdriver is needed to remove screws, while a spudger is needed to pry out the headphone jack.
O que você precisa
Wedge your finger under the bottom ridge of the SD card insert.
Pull outwards with your fingers to remove the SD card from the left side of device.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
Insert your iFixit Opening Tool underneath the front camera and gently lift up.
Remove the front camera by lifting the front camera up with your hands.
