Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will show you how to remove the battery from your Sony Xperia XA1 Ultra. You may need to replace the battery if it drains too fast or it can no longer charge. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. Additionally, a spudger is needed to lift and disconnect parts from the phone.
O que você precisa
Wedge your finger under the bottom ridge of the SD card insert.
Pull outwards with your fingers to remove the SD card from the left side of device.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
12 outras pessoas executaram este guia.
3 comentários
magnificent…i successfully change a new battery for xperia xa1 ultra…its not the time yet for this xperia to retire from service to me…thank you very much
Wher did you get the batterry from? And is it good as the original?
Where can I get the original battery
