Ir para o conteúdo principal
Sony Xperia XA1 Ultra Back Assembly Replacement
O que você precisa
  1. Sony Xperia XA1 Ultra Back Assembly Replacement, Back Assembly: passo 1, imagem 1 %32 Sony Xperia XA1 Ultra Back Assembly Replacement, Back Assembly: passo 1, imagem 2 %32
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
    How do you remove it? (Seems obvious but write for any audience, and say how to do things instead of just what to do)
    Kyle Ladtkow - Responder
  2. Sony Xperia XA1 Ultra Back Assembly Replacement: passo 2, imagem 1 %32
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
    Consider saying “loosen” instead of “soften” so that steps 2 and 3 use the same terms. Somebody may not know that heating the glue will loosen it, and so they will be confused reading “once the adhesive is loosened” in step 3.
  3. Sony Xperia XA1 Ultra Back Assembly Replacement: passo 3, imagem 1 %32
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
    sure that there is adhesive tape on backcover?
    where should it tape on at the device inside?
    looks more like only plugged together`?
    Alexander H - Responder
  4. Sony Xperia XA1 Ultra Back Assembly Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
    Period missing for first point.
  5. Sony Xperia XA1 Ultra Back Assembly Replacement: passo 5, imagem 1 %32
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
    Can you clarify what should be repeated in this step?
    Tiffany Dang - Responder
  6. Sony Xperia XA1 Ultra Back Assembly Replacement: passo 6, imagem 1 %32
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
Conclusão
Jacob Jung
Membro desde: 04/18/18
1.429 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team S16-G3, Livingston Spring 2018 Membro de Cal Poly, Team S16-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G3
Membros da 4
Autoria de 9 guias
Um comentário
What kind of adhesive should be used when reassembling the phone?
Nicholas Bates - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 7
Duração total: 3,191
