Introdução
In order to remove other parts of your device, you will need to remove the back assembly. You may also need to replace the back panel if it damaged. This guide will show you how to remove the back assembly of your Sony Xperia XA1 Ultra. A heat gun or hairdryer is needed to loosen the adhesive to open the back panel, which can become hot and potentially damage the phone. A suction cup and opening tools will be needed to pry off the cover.
O que você precisa
Wedge your finger under the bottom ridge of the SD card insert.
Pull outwards with your fingers to remove the SD card from the left side of device.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
Um comentário
What kind of adhesive should be used when reassembling the phone?
