Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Wedge your finger under the bottom ridge of the SD card insert.
Pull outwards with your fingers to remove the SD card from the left side of device.
Use a hair dryer to heat each corner of the phone.
Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
Press a suction cup on a heated corner of the device.
Hold the phone down and gently lift the suction cup to create a small gap.
Ferramenta utilizada nesse passo:Plastic Cards$2.99-
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
Slide your plastic card along the side of your phone to loosen the adhesive.
Move the card along the sides of the phone to lift all of the corners.
Lift up the back cover by lifting up the sides of the phone with your hand.
Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
Insert your iFixit Opening Tool underneath the antenna module.
Lift up gently with the iFixit Opening Tool to remove the antenna module.
Uma outra pessoa concluiu este guia.
