Introdução
This guide will show you how to remove the antenna module from your Sony Xperia XA1 Ultra. The antenna module will need to be removed to access other parts of the phone or replaced if the phone experiences connectivity issues. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. In addition, a T5 screwdriver is needed to remove screws and a spudger is used to lift up components of the phone.
O que você precisa
Wedge your finger under the bottom ridge of the SD card insert.
Pull outwards with your fingers to remove the SD card from the left side of device.
Use a hair dryer to heat each corner of the phone.
Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
Consider saying “loosen” instead of “soften” so that steps 2 and 3 use the same terms. Somebody may not know that heating the glue will loosen it, and so they will be confused reading “once the adhesive is loosened” in step 3.
Press a suction cup on a heated corner of the device.
Hold the phone down and gently lift the suction cup to create a small gap.
sure that there is adhesive tape on backcover?
where should it tape on at the device inside?
looks more like only plugged together`?
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
Slide your plastic card along the side of your phone to loosen the adhesive.
Move the card along the sides of the phone to lift all of the corners.
Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
Clarify where the screws are
Insert your iFixit Opening Tool underneath the antenna module.
Lift up gently with the iFixit Opening Tool to remove the antenna module.
Maybe add a caution that the module is hard to take off
Could use better explanation on how to take off
“to take off piece” change to take off the piece? Or even be specific, “pull with your hands to remove the module.”
also the picture makes it look as if you flip the antenna board over but it needs to be pulled up from the phone as if you bend it over it will break
Uma outra pessoa concluiu este guia.
How do you remove it? (Seems obvious but write for any audience, and say how to do things instead of just what to do)
Kyle Ladtkow - Responder
