Introdução
This guide will show the step-by-step process to replace the front facing camera of the Xperia XA Ultra. To accomplish this replacement, you will need a T3 and T5 torx screwdriver as well as a plastic spudger.
O que você precisa
Carefully remove the back panel of the phone with a plastic spudger, or other flat and thin wedge tool. Work your way around the perimeter of the case, loosening and prying gently, until there is sufficient distance between the panel and phone.
Near the top of the battery (area closest to camera) press the small latch in the highlighted area, push the latch away from the metal casing with the metal spudger.
Use the plastic opening tool to pry off the metal case. Be sure to carefully pry the casing slowly and at multiple angles and directions to insure nothing is damaged.
Using a plastic spudger, disconnect the camera from the motherboard.
Uma outra pessoa concluiu este guia.
