Ir para o conteúdo principal
Sony Xperia XA Ultra Rear Facing Camera Replacement
O que você precisa
  1. Sony Xperia XA Ultra Rear Facing Camera Replacement, Motherboard: passo 1, imagem 1 %32 Sony Xperia XA Ultra Rear Facing Camera Replacement, Motherboard: passo 1, imagem 2 %32
    • Carefully remove the back panel of the phone with a plastic spudger, or other flat and thin wedge tool. Work your way around the perimeter of the case, loosening and prying gently, until there is sufficient distance between the panel and phone.
  2. Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 2, imagem 1 %32 Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 2, imagem 2 %32
    • Remove all 9 black 4mm T5 screws.
    • Remove all 8 silver 3mm T3 screws.
    • Make sure to carefully place each screw in a secure location to avoid losing any.
  3. Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 3, imagem 1 %32 Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 3, imagem 2 %32 Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 3, imagem 3 %32
    • Near the top of the battery (area closest to camera) press the small latch in the highlighted area, push the latch away from the metal casing with the metal spudger.
    • Use the plastic opening tool to pry off the metal case. Be sure to carefully pry the casing slowly and at multiple angles and directions to insure nothing is damaged.
    • Be careful when prying near the top of the device. The metal casing can be easily bent.
  4. Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 4, imagem 1 %32 Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 4, imagem 2 %32
    • Remove the side bezels from each side, and remove the sim card cover.
  5. Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 5, imagem 1 %32 Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, gently pry off the black charge port plate, located near the bottom of the phone.
    • Remove the sim card from sim card slot using fingernail or small plastic spudger.
  6. Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 6, imagem 1 %32 Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 6, imagem 2 %32 Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 6, imagem 3 %32
    • Disconnect all four of the shown electrical connectors by gently prying up with the plastic opening tool.
  7. Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 7, imagem 1 %32 Sony Xperia XA Ultra Rear Facing Camera Replacement: passo 7, imagem 2 %32
    • Working from bottom to top, gently pry the motherboard off of the phone .
    • The camera is connected to the motherboard. Be extremely careful when removing it to avoid damage.
  8. Sony Xperia XA Ultra Rear Facing Camera Replacement, Rear Facing Camera: passo 8, imagem 1 %32
    • Using a plastic spudger, disconnect the camera from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 421
