Ir para o conteúdo principal
Sony Xperia XA Front Camera Replacement
O que você precisa
  1. Sony Xperia XA Front Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Front Camera Replacement: passo 2, imagem 1 %32
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Front Camera Replacement: passo 3, imagem 1 %32 Sony Xperia XA Front Camera Replacement: passo 3, imagem 2 %32 Sony Xperia XA Front Camera Replacement: passo 3, imagem 3 %32
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Front Camera Replacement: passo 4, imagem 1 %32 Sony Xperia XA Front Camera Replacement: passo 4, imagem 2 %32 Sony Xperia XA Front Camera Replacement: passo 4, imagem 3 %32
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Front Camera Replacement: passo 5, imagem 1 %32
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Front Camera Replacement: passo 6, imagem 1 %32
    • Peel back the RAF antenna.
  7. Sony Xperia XA Front Camera Replacement, Front Camera: passo 7, imagem 1 %32 Sony Xperia XA Front Camera Replacement, Front Camera: passo 7, imagem 2 %32
    • Remove the five black 4mm screws with a Phillips #00 screwdriver.
  8. Sony Xperia XA Front Camera Replacement: passo 8, imagem 1 %32 Sony Xperia XA Front Camera Replacement: passo 8, imagem 2 %32 Sony Xperia XA Front Camera Replacement: passo 8, imagem 3 %32
    • Pry up the black camera case with the plastic opening tool and then remove the case.
  9. Sony Xperia XA Front Camera Replacement: passo 9, imagem 1 %32 Sony Xperia XA Front Camera Replacement: passo 9, imagem 2 %32
    • Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
    • Peel back the tab past the connector.
    • Tab is stuck with adhesive.
  10. Sony Xperia XA Front Camera Replacement: passo 10, imagem 1 %32
    • Pry up the camera's connector to the motherboard with the nylon spudger.
  11. Sony Xperia XA Front Camera Replacement: passo 11, imagem 1 %32
    • Use the flat end of the nylon spudger to lift the camera out of the phone.
  12. Sony Xperia XA Front Camera Replacement: passo 12, imagem 1 %32
    • Finish removing the front camera by lifting it gently with your fingers.
Conclusão
Theresa Wilcoski
Membro desde: 04/18/18
325 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G2, Livingston Spring 2018 Membro de Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Membros
Autoria de 8 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 406
