Introdução
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
O que você precisa
11 outras pessoas executaram este guia.
Um comentário
Thanks for such a clear set of instructions. I used a hair drier rather than heat gun!
