Ir para o conteúdo principal
Sony Xperia XA Back Camera Replacement
O que você precisa
  1. Sony Xperia XA Back Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Back Camera Replacement: passo 2, imagem 1 %32
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Back Camera Replacement: passo 3, imagem 1 %32 Sony Xperia XA Back Camera Replacement: passo 3, imagem 2 %32 Sony Xperia XA Back Camera Replacement: passo 3, imagem 3 %32
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Back Camera Replacement: passo 4, imagem 1 %32 Sony Xperia XA Back Camera Replacement: passo 4, imagem 2 %32 Sony Xperia XA Back Camera Replacement: passo 4, imagem 3 %32
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Back Camera Replacement: passo 5, imagem 1 %32
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Back Camera Replacement: passo 6, imagem 1 %32
    • Peel back the RAF antenna.
  7. Sony Xperia XA Back Camera Replacement, Motherboard: passo 7, imagem 1 %32 Sony Xperia XA Back Camera Replacement, Motherboard: passo 7, imagem 2 %32
    • Pry up the copper connector next to the battery with the plastic opening tool.
  8. Sony Xperia XA Back Camera Replacement: passo 8, imagem 1 %32 Sony Xperia XA Back Camera Replacement: passo 8, imagem 2 %32
    • Remove the five black 4mm screws with a Phillips #00 Screwdriver.
  9. Sony Xperia XA Back Camera Replacement: passo 9, imagem 1 %32 Sony Xperia XA Back Camera Replacement: passo 9, imagem 2 %32 Sony Xperia XA Back Camera Replacement: passo 9, imagem 3 %32
    • Pry up the black camera case with the plastic opening tool and then remove the case.
  10. Sony Xperia XA Back Camera Replacement: passo 10, imagem 1 %32 Sony Xperia XA Back Camera Replacement: passo 10, imagem 2 %32
    • Pop off the small connector on the right side of the motherboard with the plastic opening tool.
  11. Sony Xperia XA Back Camera Replacement: passo 11, imagem 1 %32 Sony Xperia XA Back Camera Replacement: passo 11, imagem 2 %32
    • Use the spudger to take off the connector in the top right of the motherboard.
  12. Sony Xperia XA Back Camera Replacement: passo 12, imagem 1 %32 Sony Xperia XA Back Camera Replacement: passo 12, imagem 2 %32 Sony Xperia XA Back Camera Replacement: passo 12, imagem 3 %32
    • Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
    • Peel back the tab past the connector.
    • Tab is stuck with adhesive.
  13. Sony Xperia XA Back Camera Replacement: passo 13, imagem 1 %32 Sony Xperia XA Back Camera Replacement: passo 13, imagem 2 %32 Sony Xperia XA Back Camera Replacement: passo 13, imagem 3 %32
    • Pry up the camera's connector to the motherboard with the nylon spudger.
  14. Sony Xperia XA Back Camera Replacement: passo 14, imagem 1 %32 Sony Xperia XA Back Camera Replacement: passo 14, imagem 2 %32
    • Use the spudger to loosen the black connector from the top right of the motherboard.
  15. Sony Xperia XA Back Camera Replacement: passo 15, imagem 1 %32 Sony Xperia XA Back Camera Replacement: passo 15, imagem 2 %32 Sony Xperia XA Back Camera Replacement: passo 15, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Pull out the square shaped connector using tweezers.
  16. Sony Xperia XA Back Camera Replacement: passo 16, imagem 1 %32 Sony Xperia XA Back Camera Replacement: passo 16, imagem 2 %32
    • Use the spudger to detach the three copper connectors on the bottom area of the motherboard.
  17. Sony Xperia XA Back Camera Replacement: passo 17, imagem 1 %32 Sony Xperia XA Back Camera Replacement: passo 17, imagem 2 %32 Sony Xperia XA Back Camera Replacement: passo 17, imagem 3 %32
    • Use the spudger to separate the motherboard from the frame.
    • Pull out the motherboard using your fingers.
  18. Sony Xperia XA Back Camera Replacement, Back Camera: passo 18, imagem 1 %32 Sony Xperia XA Back Camera Replacement, Back Camera: passo 18, imagem 2 %32
    • Use the nylon spudger to pry up the black camera connector from the motherboard.
    • The connector is attached with adhesive.
  19. Sony Xperia XA Back Camera Replacement: passo 19, imagem 1 %32
    • Use your fingers to gently pull the camera off the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Theresa Wilcoski
Membro desde: 04/18/18
328 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G2, Livingston Spring 2018 Membro de Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 971
