Introdução
If your phone's speaker is not working properly and needs replacement, follow the steps provided in this guide to guide you through the replacement process.
O que você precisa
Set the phone screen down on a clean flat, surface.
Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
Pop the plastic cover off. To do this, gently push forward on the plastic opening tool while it is in between the cover and the phone.
3 outras pessoas executaram este guia.
