Ir para o conteúdo principal
Sony Xperia U Rear Facing Camera Replacement
O que você precisa
  1. Sony Xperia U Rear Facing Camera Replacement, Battery: passo 1, imagem 1 %32
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Rear Facing Camera Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Rear Facing Camera Replacement, Motherboard: passo 3, imagem 1 %32
    • Remove the bottom cover of the phone using the plastic opening tool.
  4. Sony Xperia U Rear Facing Camera Replacement: passo 4, imagem 1 %32
    • Remove the five 5.47mm and one 5.18mm Torx head screws using a Phillips #0 screwdriver.
  5. Sony Xperia U Rear Facing Camera Replacement: passo 5, imagem 1 %32
    • Carefully remove the back cover using the plastic opening tool.
  6. Sony Xperia U Rear Facing Camera Replacement: passo 6, imagem 1 %32
    • Pry up on the right side of the motherboard using the plastic opening tool.
  7. Sony Xperia U Rear Facing Camera Replacement: passo 7, imagem 1 %32
    • Carefully detach the flex cable using a pair of tweezers.
  8. Sony Xperia U Rear Facing Camera Replacement, Rear Facing Camera: passo 8, imagem 1 %32
    • Use the tweezers to detach the flex cable to remove the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Bader
Membro desde: 10/07/14
545 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 7-2, Leahy Fall 2014 Membro de USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 875
