Introdução
If your phone's motherboard needs to be replaced, this guide will assist you through the replacement steps.
O que você precisa
Set the phone screen down on a clean flat, surface.
Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
3 outras pessoas executaram este guia.
