Ir para o conteúdo principal
Sony Xperia U Headphone Jack Replacement
O que você precisa
  1. Sony Xperia U Headphone Jack Replacement, Battery: passo 1, imagem 1 %32
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Headphone Jack Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Headphone Jack Replacement, Headphone Jack: passo 3, imagem 1 %32
    • Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
    • Pop the plastic cover off. To do this, gently push forward on the plastic opening tool while it is in between the cover and the phone.
  4. Sony Xperia U Headphone Jack Replacement: passo 4, imagem 1 %32
    • Remove the six size 0 Phillips screws.
  5. Sony Xperia U Headphone Jack Replacement: passo 5, imagem 1 %32
    • Insert the plastic opening tool in between the body of the phone and the thin plastic back cover.
    • Lift the black back cover off of the body with the plastic tool.
  6. Sony Xperia U Headphone Jack Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Locate the earphone jack on the top left of the black plastic back cover.
    • Use the tweezers to pinch the earphone jack and remove it from the back cover.
Conclusão
Bader
Membro desde: 10/07/14
545 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 7-2, Leahy Fall 2014 Membro de USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 10
Duração total: 1,145
