Ir para o conteúdo principal
Sony Xperia U Battery Replacement
O que você precisa
  1. Sony Xperia U Battery Replacement, Battery: passo 1, imagem 1 %32
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Battery Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
Conclusão
Faisal
Membro desde: 10/07/14
216 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 7-2, Leahy Fall 2014 Membro de USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 50
Ao todo: 1,639
