Ir para o conteúdo principal
Sony Xperia TL Camera Replacement
O que você precisa
  1. Sony Xperia TL Camera Replacement, Remove Top Plastic Section: passo 1, imagem 1 %32 Sony Xperia TL Camera Replacement, Remove Top Plastic Section: passo 1, imagem 2 %32 Sony Xperia TL Camera Replacement, Remove Top Plastic Section: passo 1, imagem 3 %32
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Camera Replacement, Remove Bottom Plastic Section: passo 2, imagem 1 %32 Sony Xperia TL Camera Replacement, Remove Bottom Plastic Section: passo 2, imagem 2 %32
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Camera Replacement, Unscrewing the Back Off: passo 3, imagem 1 %32 Sony Xperia TL Camera Replacement, Unscrewing the Back Off: passo 3, imagem 2 %32 Sony Xperia TL Camera Replacement, Unscrewing the Back Off: passo 3, imagem 3 %32
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Camera Replacement, Battery: passo 4, imagem 1 %32 Sony Xperia TL Camera Replacement, Battery: passo 4, imagem 2 %32 Sony Xperia TL Camera Replacement, Battery: passo 4, imagem 3 %32
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  5. Sony Xperia TL Camera Replacement, Sony Xperia TL Auxiliary Cord Replacement: passo 5, imagem 1 %32 Sony Xperia TL Camera Replacement, Sony Xperia TL Auxiliary Cord Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Camera Replacement, Motherboard: passo 6, imagem 1 %32 Sony Xperia TL Camera Replacement, Motherboard: passo 6, imagem 2 %32 Sony Xperia TL Camera Replacement, Motherboard: passo 6, imagem 3 %32
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
  7. Sony Xperia TL Camera Replacement, Camera: passo 7, imagem 1 %32 Sony Xperia TL Camera Replacement, Camera: passo 7, imagem 2 %32 Sony Xperia TL Camera Replacement, Camera: passo 7, imagem 3 %32
    • 'Use the plastic opening tool to detach the camera from the motherboard.'
    • The camera attachment is on the back of the motherboard.
Conclusão
Adam Giniger
Membro desde: 09/22/14
1.303 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 4-4, Brown Fall 2014 Membro de USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 9
Duração total: 205
