Ir para o conteúdo principal
Sony Xperia TL Battery Harness Replacement
O que você precisa
  1. Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: passo 1, imagem 1 %32 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: passo 1, imagem 2 %32 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: passo 1, imagem 3 %32
    • Use the plastic opening tool to pry the top plastic section off.
    Pergunte ao FixBot
  2. Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: passo 2, imagem 1 %32 Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: passo 2, imagem 2 %32
    • Use the plastic opening tool to pry the bottom plastic section off.
    Pergunte ao FixBot
  3. Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: passo 3, imagem 1 %32 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: passo 3, imagem 2 %32 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: passo 3, imagem 3 %32
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
    Pergunte ao FixBot
  4. Sony Xperia TL Battery Harness Replacement, Loud Speaker: passo 4, imagem 1 %32 Sony Xperia TL Battery Harness Replacement, Loud Speaker: passo 4, imagem 2 %32 Sony Xperia TL Battery Harness Replacement, Loud Speaker: passo 4, imagem 3 %32
    • Use the plastic opening tool to remove the loud speaker module.
    Pergunte ao FixBot
  5. Sony Xperia TL Battery Harness Replacement, Auxiliary Cord: passo 5, imagem 1 %32 Sony Xperia TL Battery Harness Replacement, Auxiliary Cord: passo 5, imagem 2 %32
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
    Pergunte ao FixBot
  6. Sony Xperia TL Battery Harness Replacement, Battery Harness: passo 6, imagem 1 %32 Sony Xperia TL Battery Harness Replacement, Battery Harness: passo 6, imagem 2 %32 Sony Xperia TL Battery Harness Replacement, Battery Harness: passo 6, imagem 3 %32
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
    Pergunte ao FixBot
  7. Sony Xperia TL Battery Harness Replacement: passo 7, imagem 1 %32
    • The final step is taking the entire harness off of the phone.
    Pergunte ao FixBot
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Adam Giniger
Membro desde: 09/22/14
1.303 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 4-4, Brown Fall 2014 Membro de USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 59
Ao todo: 610
