Ir para o conteúdo principal
Sony Xperia T2 Ultra Dual Top Speaker Replacement
O que você precisa
  1. Sony Xperia T2 Ultra Dual Top Speaker Replacement, Rear Case: passo 1, imagem 1 %32
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Top Speaker Replacement: passo 2, imagem 1 %32
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Top Speaker Replacement, Removing the internal cover: passo 3, imagem 1 %32
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Top Speaker Replacement: passo 4, imagem 1 %32 Sony Xperia T2 Ultra Dual Top Speaker Replacement: passo 4, imagem 2 %32
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Top Speaker Replacement, Top Speaker: passo 5, imagem 1 %32 Sony Xperia T2 Ultra Dual Top Speaker Replacement, Top Speaker: passo 5, imagem 2 %32
    • Use the tweezers to remove the top speaker carefully.
Conclusão
Shiqing Wang
Membro desde: 03/01/17
155 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G3, Harley Spring 2017 Membro de IUPUI, Team S1-G3, Harley Spring 2017
IUPUI-HARLEY-S17S1G3
Membros da 4
Autoria de 3 guias
3 comentários
Sony t2 ULRA PHONE How Display OR TOUCH DIZASTER replacement
Rajib Kalita - Responder
I can see and touch is work properly but display is broken, please tell what is replace display or touch disaster?
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 2,018
