Introdução
The motherboard is where all the different chips that make the phone run are located. The motherboard needs to be replaced anytime one of the chips on it breaks in order for the phone to work again. Since all other components of the phone connect to the motherboard, all the connectors must be disconnected in order to safely remove the motherboard.
O que você precisa
Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
To take out the back facing camera, flip open the flap labelled ‘film’ to reveal the chip that connects to the motherboard.
Then using the tweezer, carefully remove the back facing camera component.
Using the tweezer, carefully pry open the chip for the front facing camera as shown. Then using the tweezer, carefully remove the front facing camera component.
Using tweezer, locate the audio jack as shown and pull out the chip connected to the motherboard.
Carefully remove the audio jack by using the tweezers and pull firmly straight out of the motherboard.
Using tweezers, locate the battery connector and carefully pull up to disconnect it.
4 outras pessoas executaram este guia.
2 comentários
Mayrka D5322 ke bad cahiy
