Ir para o conteúdo principal
Sony Xperia T2 Ultra Dual Battery Replacement
O que você precisa
  1. Sony Xperia T2 Ultra Dual Battery Replacement, Rear Case: passo 1, imagem 1 %32
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Battery Replacement: passo 2, imagem 1 %32
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Battery Replacement, Removing the internal cover: passo 3, imagem 1 %32
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Battery Replacement: passo 4, imagem 1 %32 Sony Xperia T2 Ultra Dual Battery Replacement: passo 4, imagem 2 %32
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Battery Replacement, Battery: passo 5, imagem 1 %32 Sony Xperia T2 Ultra Dual Battery Replacement, Battery: passo 5, imagem 2 %32
    • Using the Tweezer, carefully pry open the corresponding chips that are attached to the battery as shown. Then using the spudger, pry the battery away from the phone and watch out for the sticky substance keeping the battery to the phone.
Conclusão
25 outras pessoas executaram este guia.
Christina Wojaczyk
Membro desde: 09/26/14
1.450 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 13-3, Staggers Fall 2014 Membro de USF Tampa, Team 13-3, Staggers Fall 2014
USFT-STAGGERS-F14S13G3
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 16,469
